Room Separators working on wrong levels
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
filip.kabelis
894 Aufrufe, 2 Antworten
I have a weird issue with Room Separators - they seem to work on wrong levels.
As you can see below - I have somewhat broken room separator on floorplan L08, but it actually changes room boundaries of a room on floorplan L06 - two levels below! Can someone explain???
Pink lines are the room separators.
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: filip.kabelis
There are many factors. Check and see if there is hidden curtainwall or wall that drawn in L6 and extend up to L8. Also check with your level and see if your computation height is set to large number. It should be 4'-5' range (1.2-1.5m)
Nachricht 3 von 3
filip.kabelis
als Antwort auf: syman2000
Actually got it working, I had a Dynamo script generating these Room Separators, which it turned out that had a sorting problem and putting these lines on wrong levels.. Now it's fine :leicht_lächelndes_Gesicht: Case closed
