Room separator
2 REPLIES 2
PhilvK
226 Views, 2 Replies
Room separator
Why am I getting the warning message below please when I try to add a Room Separator?
2 REPLIES 2
L.Maas
in reply to: PhilvK
Usually this is when you try to place elements that lay outside your view range. Or that category is not visible due to your graphics overrides settings.
Louis
Please mention Revit version, especially when uploading Revit files.
tuuletin
in reply to: PhilvK
You have switched off those lines (room separators). Go to the Visibility/Graphics for the view → Model Categories → Lines → Room Separators and switch it on.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Forma Design Contest
