Room separator
3 REPLIES 3
martynas.stankeviciusKEZJW
227 Views, 3 Replies
Room separator
I keep running into a problem with revit room separator. I have deteled all the room separations I have created before and now when I try to place them again, the number count is wrong. It doesn't start with 1, it starts with 270 and keeps going up. How do I reset the number count ?
Additional question. How do I fix the numbering for different levels, example: I have two floors, I want the first floor to have numbering 1.1...1.20...1.21 and the second floor to have 2.1...2.20...2.21. How do I achieve that ?
Tags (1)
Labels (1)
3 REPLIES 3
Deleting rooms from the model does not wipe them out.  Create a room schedule and delete all rooms from it then you can create new rooms using the previous numbers.
To your 2nd question, edit the room tag family and add Level to the label:
Where are you seeing this room separator "number count"?
Thank you, everything worked !
Forma Design Contest
