I am working on a multi story building in which when i place the room tag it divide the area in parts can anyone explain why this is happening it make the room boundary itself
Room Tags don't create Rooms, so there must be something Room-bounding in the places you indicate.
Hey, my guess would be room separation lines. Maybe try turn the on under Lines in the Model Categories in Visibility Graphics, also set the view to wireframe after to make them easier to see, sometimes they hide under floors/carpets.
If not then likely a hidden element or wall potentially under a different phase or even workset that isn't visible in the view?
Hope this helps!
Also go to the section view, enable Room Reference in the Visibility Graphics and check the room heights and adjust if necessary
Thank for your reply
I have set all the height of my rooms
I have also find the room separation line and adjust it but it doesn't work
you can see in this image it divide a single space into further. even in this area there is no separation line.
Check level below / above. Also in 3D if there are any hidden room bounding elements not shown in plan.
I have check the all there is no hidden room even I have cross check with room schedule floor wise
OK I have delete the all room in my project after that i have place a new it again not pick the whole area
do you have any phases ?
could you post a section with no template? I or 1 too?
