Room Schedules
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Scary99
441 Aufrufe, 3 Antworten
Room Schedules
I have tagged rooms and created a room schedule.  I am attempting to enter the fields (base finish, ceiling finish, wall, etc) but having no luck.  My text says to select the ROOMS (not the room tag) for a group of rooms (bedrooms for instance), move the cursor near the Room Tag until you see the room highlighted and with an "X".  I should get a Properties Palette that allows me to enter Identity Data (example in my book).  However, when I try highlighting the room as indicated nothing happens and get no such palette.  Where have I made a mistake?  File attached.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Scary99
CTRL + 1 to toggle Properties palette
Nachricht 3 von 4
Scary99
als Antwort auf: ToanDN
Thanks for the fast reply.  I need to open a palette that will allow me enter the finish of each room.  The properties palette I have does not have that option.  The identity data area calls out room number, name, comments, finishes and so forth.  Thus far I have been unable to pull this palette up.
Nachricht 4 von 4
Yes it does. Properties of everything are in that one palette. Select a room or several rooms and look at tge palette, you may need to scroll down a bit.
