Room Schedule
Room Schedule
Room Schedule
I'm trying to generate a room finish schedule on an existing model therefore I am unfamiliar with how the project was initially set up. I noticed that in the schedule I have duplicate rooms appearing anywhere from 2-8 times per each room number. For example, I have 7 Room number 147's. Now, when I ask revit to show me where these rooms are on the plan, this is where it gets interesting. They are lights, doors, windows, mullions, and columns. Obviously these are not rooms, but revit is telling me these are rooms. I also cannot type into cells on the schedule even when I should be able to, in particular, a comment column, generated specifically for this reason. Has anyone else ever come across an issue like this?
Sounds peculiar. Can you post the file?
I cannot. I am only curious if this has happened to anyone else and how they solved it.
Not to me. Like I said, this sounds peculiar.  Are you by chance using a Key Schedule?
