Hi all,
I want tio schedure exterior room in this way From room number to Room OUT.
Any idea?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Room aware? You mean like the way a Door can use a Room Calculation Point to show To Room/From Room? Or is that exactly what you are are looking for?
Modify the Room Calculation Point | Revit Products 2016 | Autodesk Knowledge Network
FWIW: Doesn't have to be a Door. Could be Room Aware Opening Family as well.
If you are looking to add the To/From room values to the doors themselves, that would require to you create some custom To/From room parameters for your doors so you can fill that information out.
I wrote a blog post on this exact issue. It uses our software to expedite the filling out of the data, but you can certainly do it manually. If you have a lot of doors to process, it could take a lot of time manually.
More info here:
https://ideatesoftware.com/blog/using-ideate-bimlink-to-push-to-and-from-room-data-into-door-tags
Hope this helps.
Sash
Surely I did not express properly the issue. I want to achieve smt like in pic.
That looks more like a door schedule than a room schedule
1-You can add the From/To room in a door schedule (Fields tab / Drop down Menu)
2-To show in the schedule you have to edit the door family and check the "Room Calculation" box then reload into
your project
My mistake in title it is a DOOR schedule.
Unfortunatelly if there is no Room for OUT I cannot show it in Schedule.
Please check previusly pic.
Well because you do not have a room OUTside the building
... add some room separators outside and add a room
Alternatively, you can
1. add a project Parameter to door to identify Exit doors and add it as a hidden field to the schedule.
2. In the schedule add a calculated parameter with an if statement ...
A. if door is exit it fills in text "EXIT"
B. and if door is not exit it fills in Room To: Number
Here is the alternative mentioned above...
