Room Schedule in Revit
7 ANTWORTEN 7
Nachricht 1 von 8
allaweya
295 Aufrufe, 7 Antworten
Hi everyone
When selecting a room in a Revit model, there are four instance parameters under Identity Data section in Properties Palette which are:
Base Finish
Ceiling Finish
Wall Finish
Floor Finish
So, I have 4 questions
  1. Where are these locations with respect to layers that includes in each Ceiling and walls and floors
  2. What is the difference between Base Finish and Floor Finish
  3. I ask what's the purpose of adding this info after ending this info during going to edit Types for walls and Ceiling and floors
  4. What are the benefits of adding these parameters in Room Schedule
Tags (2)
7 ANTWORTEN 7
Nachricht 2 von 8
RC_RVT
als Antwort auf: allaweya
    1. They aren't, these are just for the room, not for the actual families involved e.g. ceilings, walls, floors.
    1. Base finish is e.g. plinth/skirting Floor finish is e.g. carpet/tiles
    1. Because varied paints between rooms and varied floor types might be hard to achieve easily, so this gives you a way to list what the finishes are without actually having to change them.
    1. So that you can easily see and edit the finishes for each room without having to go into each physical room
If this works, please mark it as an accepted solution. This helps make the forum a better place.
Nachricht 3 von 8
TripleM-Dev.net
Those parameters are just plain text parameters, no link with actual geometry.
It can be used as a simpel info about finishes without the need to actual model them.
We mostly use them (and other parameters) for the global finishes (those that are used for the most part in the room), and specific finishes (part of wall or floor etc is actually modelled.) Easy to do in early stage of project. In combination with a Room ColorFill legend is very clear where the material are applied (globally)
The base finish is actually the base of the wall (or better where the floor and wall meet, like a plinth)
Tip: use them in combination with KeySchedules, so the values are equal. kind of type for rooms.
Nachricht 4 von 8
If you want to associate actual materials to rooms then look into roombook extension.
Nachricht 5 von 8
allaweya
als Antwort auf: RC_RVT
Hi @RC_RVT
Thank you for sharing your info
I understand that wall finish is just used for PAINTING a room to call Paint-1 for room 1 and Paint-2 for room 2 and else I still not understand the reason to include these parameters especally that we can include all these parameters in walls and ceiling and floor layers to be able to find their quantities by Material Takeoff tool
Nachricht 6 von 8
allaweya
als Antwort auf: ToanDN
Hi @ToanDN
Thank you for your advice
Nachricht 7 von 8
allaweya
Today, I read the following info from Residential Design Using Autodesk Revit 2021 eBook by Daniel John Stine (Page 13-14)
Hopefully, in the near future. Revit will be able to enter the finishes based on the wall’s Materia! settings, as well as floor and ceiling types previously created in the project!
So I hope for Revit users who use last versions of Revit if there is any changes about my concerns
Nachricht 8 von 8
RC_RVT
I use Revit 2025, and there is no change to the Room Schedule, if this is what you are asking. If your query has been resolved, can you accept the solution please.
