Room Schedule (Area) greater than requirement
3 ANTWORTEN 3
Nachricht 1 von 4
Yeu.Ng
326 Aufrufe, 3 Antworten
Hi all
Not sure you guys have encounter the below situation.
I need to show the room area is greater than the requirement.
However, my issue is that I have a multiple room area called the store and combine must archive 6m²
So my formula is Area > Requirement
But when without itemize the area is greater than requirement but show No. (see screenshot)
I know what causes it but I not sure what is the solution to archive
my goal is to archive area > requirement when all same department room area is combine
Bedroom combine is 24m² requirement is 25m²
Store combine is 6.5m² requirement is 6m²
Thank you
With itemizeWith itemizewithout itemizewithout itemize
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Yeu.Ng
Sounds like a rounding issue.  You can modify units/precision under "Field Format" on the Format tab.
Nachricht 3 von 4
It is not easy to accomplish what you want in Revit because Revit can't do pivot tables like Excel. I can play around with formulas but no promises.
Attached is an example that involve some entering some data manually.
Nachricht 4 von 4
Yeu.Ng
als Antwort auf: ToanDN
Thanks. I will take a look.
