I am looking for a way to push properties to the elements in a room. Basically I have assigned information to rooms but i also want this information to be pushed to the elements (windows, wall, doors, floors, ceiling) of the room.
Can someone assist?
SOME CLARIFICATION: Example: There are properties to the room (room number, WBS code etc) those i would like to only fill out for the room and then automatically populate the same property fields in Doors/Windows etc. So after this operation the WBS code is not only filled for a room but also (without manual action) the property WBS for the windows.
Sorry don’t get you? Anyway you can add those text in your tag room name just edit family room name and add? Thanks
I hope the clarification helped. The intend is that i fill out the WBS code as a room property, however the WBS code in the elements (Windows->WBS) are automatically populated (saves lots and lots of manual labor)
Revit does not support this natively. You would need to create some sort of automation with the API or a Dynamo script or leverage a third-party solution to do this.
