Room numbering per linked model instance
mostafa_saber
mostafa_saber
Hello Revit Gurus,
I'm looking for a smart way to add rooms inside nested links, then do the numbering in the main model based on room number & link name. I don't seem to find a way to achieve this. Any ideas?
Why don't you just tag the linked rooms?
mostafa_saber
Hi @ToanDN, thank you for your reply.
I'm tagging the linked rooms, but there numbers are not unique per unit since they get the room number from the linked typical unit model. For example, if the dining room number is 12 in one unit, it still shows the same number when I mirror or copy that typical unit.
Ideally, I would want to add Link Name to the Room tag, so it becomes U01-12, or U02-12 based on linked model instance.
I hope I explained it better & thank you for your support.
Create different room tag types with different prefixes.
mostafa_saber
That's a simple and effective solution. Thank you @ToanDN
