Room not wrapping around column
18 ANTWORTEN 18
Nachricht 1 von 19
1298 Aufrufe, 18 Antworten
Dear Revit user community,
the project I am working on has columns placed close to the facade. When rooms are placed, they don't wrap around the column. A gap as shown in the screenshot is the result. Due to this, a small part of the area is left unconsidered.
How can this issue be solved?
Tags (3)
18 ANTWORTEN 18
Nachricht 2 von 19
hmunsell
als Antwort auf: Anonymous
are you referring to the ares left behind the round column? are there any "supports" from the column to the wall that could be blocking the room from warping around it?
Howard Munsell
Nachricht 3 von 19
als Antwort auf: hmunsell
Hi @hmunsell
all the revit links are set to non-room-bounding in this model.
There are only "rooms" and "room separation lines" in this model.
Best
Nachricht 4 von 19
I don't understand why you can't work around this issue by referencing Room Separation Lines instead of Room Bounding Elements.
Nachricht 5 von 19
als Antwort auf: barthbradley
Hi, I am not using any room-bounding elements.
My model only contains room separation lines and rooms. I will only be handing in a model with rooms/ room separation lines.
Best
Nachricht 6 von 19
Are you saying that the first screenshot you posted shows the result of creating a Room using Room Separation Lines ONLY?
Nachricht 7 von 19
yes...the plan you see in the background is just for visual reference.
Nachricht 8 von 19
Use a polygon instead of a circle.
Nachricht 9 von 19
Revit room calculations have some limit when dimensions are less than a certain value, 275 mm or something in that range.
Nachricht 10 von 19
als Antwort auf: ToanDN
Is there any way to tweak this range? It seems to be a fairly large number.
Nachricht 11 von 19
@barthbradleypolygons instead of circles produces the same result
Nachricht 12 von 19
How small are these diameters???
Nachricht 13 von 19
dimensions in millimetres
Nachricht 14 von 19
Draw a room separation line connecting the column and the exterior boundary.
Nachricht 15 von 19
Thanks for the suggestion, however that doesnt help in corner situations.
Nachricht 16 von 19
Total Room Area not substracting Columns - ((# of Columns)*(pi()*(Radius if each Column)^2))  = Dead on Ballz Accurate Room Area.
:zwinkerndes_Gesicht:
Nachricht 17 von 19
See attached.
Nachricht 18 von 19
I would do it that way.  Smart.
Nachricht 19 von 19
Thanks @ToanDN
this works as long as you have a certain distance between the wall and the column (line drawn needs to have a certain length).
