Room not showing in plan
17 ANTWORTEN 17
Nachricht 1 von 18
TeresaXMJLQ
680 Aufrufe, 17 Antworten
Room Food Storage is showing up on the RCP but not on the floor plan. I do not have any plan regions in the area. If I try to tag the floor plan I get a message it is already there and will be duplicated.
Any ideas?
17 ANTWORTEN 17
Nachricht 2 von 18
syman2000
als Antwort auf: TeresaXMJLQ
Have you change the room height? Also check and see if the room isn't hidden by element accidently or misplaced in the wrong workset.
Nachricht 3 von 18
TeresaXMJLQ
als Antwort auf: syman2000
Yes and Yes, it is not hidden either.
Thanks for you ideas though-
Nachricht 4 von 18
Can you select that room on the RCP and show its properties here?
Nachricht 5 von 18
TeresaXMJLQ
als Antwort auf: ToanDN
yes
Nachricht 6 von 18
@TeresaXMJLQ wrote:
yes
It is not a yes or no question :zwinkerndes_Gesicht:
Nachricht 7 von 18
TeresaXMJLQ
Attached is the properties
Nachricht 8 von 18
What if you change the Computational Height of the Level from 3'-0" to 0?
Can you cut a section, turn of Room Interior Fill for the section view and see what you get?
Nachricht 9 von 18
TeresaXMJLQ
I cant its greyed out
Nachricht 10 von 18
You change Room Computational height but opening a Section or Elevation, select the Level and change from its properties.
Nachricht 11 von 18
TeresaXMJLQ
Nothing shows up in the Floor Plan view still.
Nachricht 12 von 18
Can you share the model here?
Nachricht 13 von 18
TeresaXMJLQ
No sorry~
Nachricht 14 von 18
syman2000
Is your room set to volume?
Nachricht 15 von 18
TeresaXMJLQ
It is set to Areas Only. This is the message I get when I try to tag the room.
Nachricht 16 von 18
syman2000
Cut the section. As well move the room away from the stair opening.
Nachricht 17 von 18
TeresaXMJLQ
for goodness sakes lol, Thanks~! I moved it away from the stair and added a room separation line and that fixed it.
Thanks for spending so much time helping me figure this out!
Nachricht 18 von 18
Does the room show if you create Plan View from scratch (View > Plan Views > Floor Plan > Uncheck Do not Duplicate...)?   If so, turn on Plan Region and delete any on the Plan view that the room is not showing.
