How can adjust room names (with area) in the center of the room? thank you
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
When auto tagging the tag is placed at the location point of the room (tag can be manually moved to different location , by selecting the tag).
When you want to see area you need to load (or make) the right tag.
Louis
Please mention Revit version, especially when uploading Revit files.
thank you for your reply. please see attached. i don't know what is caused having this problem. when i move the cross sign of the text it become question mark (?).
The origin point of your tag seems to be relative far down (possibly because of other parameters that can be shown in the tag), see screenshot for example. When you move the tag down the origin point moves outside of the room causing it to loose connection with that room and therefore your question mark.
Possible solution is to activate leader (keeps the connection to the room) or change/modify the tag so that the origin point is closer to your text
Louis
I'd use Dynamo for this task....
You ca see how it works in the following screencast:
Constantin Stroescu
