Room material Tag for walls
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
dicky
1093 Aufrufe, 4 Antworten
Which tag or how is it possible to call out the North East South West Finishing within a room property?  Please see attached image for explanation.  Thank you.
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
Ahmed_Muharram
als Antwort auf: dicky
you should make an annotation family ( room Tag ) using your parameters "parameters must be shared parameters"
you can adjust the shape and the text you want
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Nachricht 3 von 5
dicky
als Antwort auf: Ahmed_Muharram
Thank you, that worked, I then used "project parameters" to refer to the newly created "shared parameters" and made each new data field as an instance and assigned the "rooms" category to it.
Any further thoughts on automating this further by extracting the "mark" in the revit annotation information from the material brower?
Nachricht 4 von 5
A_Jacq
Hey there, can you please share the tag family to see how you managed to solve that?
Nachricht 5 von 5
mhiserZFHXS
als Antwort auf: A_Jacq
Its just a room tag. Look up how to make them. Its pretty straight forward.
And just a note, it is not possible to pull the actual floor, wall and ceiling materials in rooms into a room tag with vanilla Revit. These are still input manually. You can do it with Dynamo, but that gets pretty complicated and how its done really depends on firm standards.
