Room Finish Schedule with Multiple Wall Tags HELP
2 ANTWORTEN 2
Nachricht 1 von 3
mmckinney45
595 Aufrufe, 2 Antworten
I have been trying to create a room tag that shows the room finishes and within this tag it also shows N, S, E, W wall finishes that I can edit separately for each room. I will link a photo of what I am trying to accomplish. I have been having two issues while trying to create this.
Issue 1) The room tag gives me the option to type in the wall finishes but if I do that, it will change all the walls to the same finish when I'm wanting four different wall finishes. (I'm assuming this has something to do with a parameters issue?) I have a room finish legend and changing it on there and on the Identity Data regions, it still won't smart tag.
Issue 2) I have tried several different methods and with this method I create new parameters for each all but each tag is a question mark and I am unable to even click into the finish to change anything.
I would love some input and have tried so many options that I'm starting to think it's not possible?
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: mmckinney45
You would need to create 4 sets of finish parameters.
Maybe take a look at Roombook extension and see if you can use it to get the actual finishes from the model for each room.
Nachricht 3 von 3
mmckinney45
als Antwort auf: ToanDN
I have created each wall as it's own custom parameter. I may just have to end up making them a dummy tag I think
