Room filter not showing in 2D plan view, rules are correct
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
revitmuhandis
135 Aufrufe, 2 Antworten
I created filter for ROOMS and DOORS. The goal is to make them different colors based on a fire rating parameter.
It works fine with the doors, but it doesn't work with the rooms for some reason.
Before you ask, yes I ticked the box to activate right the filters.
Thanks for reading.
2 ANTWORTEN 2
Nachricht 2 von 3
VM_Jekabs
als Antwort auf: revitmuhandis
There has to be a color scheme applied to the plan for you to be able to override room fills with a filter. Or just create a room color scheme with fire rating rules.
Nachricht 3 von 3
revitmuhandis
als Antwort auf: VM_Jekabs
I see, it did work
