Hello There, I have a set of groups and I am assigning rooms to them but when I try to use a color scheme then it doesn't show the colors. if I add a room out of the groups, then the colors are displayed, but with the group it doesn't work. Is there a way to solve it?
Check:
Phasing?
Room separation lines?
Design Options?
Linked model? (room bounding, does it have rooms in it?, etc.)
Well, they aren't being displayed. If I select the group then I can see the colors, but only when it's selected.
Everything is ok. the problem is in the group. if I assign a room outside the group then it works. If I select the group where the rooms are created, then It shows the colors.
No, I just created a group and placed a room inside it. Then when I add a color scheme then it doesn't display the colors.
@Anonymous wrote:Well, they aren't being displayed. If I select the group then I can see the colors, but only when it's selected.
Are you sure that you "can see the colors...when [the Group] is selected"? I find this odd, since I can't. When I select a room Group, the highlights a bluish transparent tint, making it impossible to discern any color. Are you sure you have a Color Scheme associated to the View? Room Color Fill Subcategory checked?
this is when selected
notice it doesn't show the colorsodd indeed, I don't understand why it happens. There are many elements, and if I ungroup them ( so the colors be displayed, 'cause it works normally outside of the group) I will have to deal with all those elements separately
