How do I get the room calculation point working? cant change/modify the grips.
Working how? It's extents/location? Open the Family and reposition it.
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-7CA9496D-205E-4838-A669-37C1DA7DEB67
i want to keep the door sing but change the calculation point so that's exterior of the door.
Yes. To Room and From Room but change room WITHOUT changing to door swing.
I strongly advise against tuning on Room Calculation point for doors. If you do that, every time you change the door swing it changes the room. We change Room From and Room To via schedule, not via door swing direction.
That door doesn't need its room calculation point to be turned on and it should still recognize room to and room from.
What @ToanDN means (I believe) is this:
If you have either the From: Room or the To: Room in your schedule you can swap out the associated rooms via the pulldown in the schedule.
OK. how do I do this, wanting to keep the door swing OUT and keep the door associated with AV Studio?
If I change to the TO, it also changes the swing.
