Room bounding lost in Linked File
15 REPLIES 15
Message 1 of 16
998 Views, 15 Replies
Why is this happening when I use a Revit room bounding linked file? I have selected room bounding on the linked file but it still wont work. Please help.
Labels (1)
15 REPLIES 15
Message 2 of 16
Work how?   Like cook and clean and whisper sweet nothings in your ear?
Message 3 of 16
ennujozlagam
share your file so we can check? thanks
Message 4 of 16
Are the exterior walls from the link as well?
Message 5 of 16
TripleM-Dev.net
Maybe the walls of the link themself aren't have roombounding disabled?
- Michel
Message 6 of 16
That didn't translate correct. 😂
Maybe the roombounding property of the walls themself in the link are unchecked?
Message 7 of 16
in reply to: ToanDN
Yes the wall are in other linked files as well. My best suspicion is that the linked file-level does not match my own...
Message 8 of 16
How is it not working?
Message 9 of 16
in reply to: barthbradley
it is only room bounding to some but not to others. They should all be hatched in.
Message 10 of 16
RobDraw
You need to explain what you are doing.
Are you showing us rooms in the linked file or are you trying to make rooms?
Rob
Message 11 of 16
Just post the files.  Or, at minimum, diagram your workflow -- maybe through a color-keyed flow chart.
Message 12 of 16
1. Link file to shared coords
2. Check Room bounding
3. Check room bounding on walls is selected
4. Check room separation lines are on in view
5. Tag all (including linked files)
6. See below - room unbound
Message 13 of 16
I managed to fix the issue by what I thought was unassigned rooms interfering. But then I did something and the room bounding has been lost again and I can't figure out why. 😞 see the same file below
Message 14 of 16
TripleM-Dev.net
Maybe Phases not matching between linked and host file?
Just guessing at this point....
Message 15 of 16
in reply to: TripleM-Dev.net
how do you change the phase of the host file pls?
Message 16 of 16
Phase Mapping. Select Link and check under its Type Properties.
