Room Bounding Issue
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
emcordova
484 Aufrufe, 4 Antworten
Room Bounding Issue
Having an issue with the room tags and room bounding. I am attempting to place a room tag but revit seems to be reading the rooms below. I have tried editing the view range, adding a plan region for that level but the room tag doesn't seem to be identifying the room as room bounding. The properties show all the walls as room bounding in that level. The floor is also room bounding so I am not sure why it's not letting me tag it.
Is there a solution to this?
4 ANTWORTEN 4
Nachricht 2 von 5
vitorbortoncello
als Antwort auf: emcordova
Check the heights of the rooms
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
mhiserZFHXS
Are the rooms below coming up too high?
Nachricht 4 von 5
mdeguzman-CP
Try to create a Floor Plan view associated to that level as to what room you are trying to create. The split level might have been causing that issue.
Once you create that level, create the 'room' there, adjust the limits and go back to your overall plan and now do a room tag. I hope that works.
Nachricht 5 von 5
emcordova
als Antwort auf: mdeguzman-CP
Yes, that helped.
