How do i hide the room boundary cross hairs from a floor plan in a view port? It doesn't print but it is visible in the view port space
Thank you for your suggestion, unfortunately that did not work.
Here is a screen shot of the issue. Is there a setting in visibility graphic that hides these lines in a view port?
That's the Reference handle (grab it to move the intersection). None of that Reference Line work is going to Print if that's the concern.
You are still not turning Reference off.
