Room boundaries are not enclosed when upgrading from revit 2015 to 2017
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
AhmadAdawi
1094 Aufrufe, 4 Antworten
When I upgraded the models from Revit 2015 to 2017 for large project which have large number of rooms, warning massage appears (Room is not in a properly enclosed region)
Is there any way to keep bounding elements or room separation lines when upgrade the models from 2015 to 2017 ?. Or to export bounding elements from Revit 2015 to 2017 after upgrading to same rooms ?.
My Regards,
Ahmad Adawi
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: AhmadAdawi
Do you have links set as Room boundaries? Are they upgraded as well?
Nachricht 3 von 5
ennujozlagam
@AhmadAdawi hello, you can use room separator in your model in Revit 2015 and check if they are hidden in visibility/Graphics overrides in your views and unhide them before upgrading into 2017and see if helps. thanks
Nachricht 4 von 5
this may be a stupid question - are there any unplaced rooms in the original before you upgrade? check the room schedule.....
Nachricht 5 von 5
AhmadAdawi
als Antwort auf: ToanDN
Exactly, I have structural and other ARC models linked to this model. when I Make extend for wall as following shots the room will be enclosed, but if I use link as boundary it does not work.
Please advice if you have any idea.
Note: Columns are from linked model.
