Room Area measurement at wall
5 ANTWORTEN 5
Nachricht 1 von 6
406 Aufrufe, 5 Antworten
I know you can set how you want to measure room area at walls globally i.e. centerline of wall, wall finish etc.
I need to be able to set different walls to override the global setting. I need to measure the room areas at the wall centerline at interior walls and to the interior finish at exterior walls. This makes a simple task tedious and complicated.
Does anyone know if there is any way or if there is an app allowing an override for room measurement per wall.
I am sure many have struggled with this and a solution would be huge.
Thank you.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Make the exterior walls not room bounding and draw room separation lines where you want.
Nachricht 3 von 6
als Antwort auf: ToanDN
That is what I have been doing and it is what is causing a lot of extra work and problems which is why I posted this
Nachricht 4 von 6
syman2000
Have you check out Area plan? I usually create area plan to define the boundary area I want. Room is limited and sometimes the workaround is too complex.
Nachricht 5 von 6
als Antwort auf: syman2000
Yes I've done that and its time consuming drawing all those lines on a large project, plus you need to use different tags.
I am trying to see if there is anyway to override the room measurements per wall other than drawing separation lines??
Nachricht 6 von 6
