Roof
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
397 Aufrufe, 5 Antworten
Roof
Hi - Does anybody know how to make this type of roof in Revit?
5 ANTWORTEN 5
Nachricht 2 von 6
ennujozlagam
als Antwort auf: Anonymous
hello, you can try to refer to this LINK. thanks
Nachricht 3 von 6
Ilic.Andrej
I assume that roof is similar to the one described in this detail. So, there are different ways to model it. My suggestion would be to simply model eaves independently. Or you could create a mass and then roof by faces.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 4 von 6
constantin.stroescu
I would use in such a case a Mass Element using Sweeps and then Roof by Face.
I made a rough screencast on the subject:
https://knowledge.autodesk.com/community/screencast/132cb2bd-76a4-475d-bcad-1acfbec190e3
Constantin Stroescu
Nachricht 5 von 6
basically the same as in the first example , but different in the way the masses are combined.
https://knowledge.autodesk.com/community/screencast/89c0172a-65f2-47af-ad26-4c87bb0fdc00
Constantin Stroescu
Nachricht 6 von 6
als Antwort auf: constantin.stroescu
Thanks a lot for the help! Smiley (fröhlich)
