Modify Sub-Elements with 5 Points and 10 Split Lines will get you there. Just need to first lay down some Ref. Planes to find the intersections for points and to calculate the elevations for the split lines. You only need to find elevations for the 3 split lines @ ridges.
I'm going suggest a different approach then. TWO Roofs joined together via Join Geometry. I think these screenshots should say it all.
Many extra lines are created when drawing. Please help me create this roof.
