I have 2 roofs at 2 different heights. I was able to connect the other roof super easy, but the left roof seems to be giving me trouble. I have tried using the join/unjoin roof command, but it gives the the error message of "Part of the roof to be joined misses the target face."
Not sure what I am supposed to do now.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I've got to model it as a roof by extrusion and cut by a void, then join with the left roof.
https://knowledge.autodesk.com/community/screencast/3f5abcb7-13a5-49c2-a589-11263d1cb595
You can try to snap on the Wall Face from bellow instead of pick on the Roof Face (sometimes this works)
If you can not manage so , I suggest to use Void Component > Roof :
Constantin Stroescu
