Roof wall join - one side roof misses
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
shivraj.panaich
3807 Aufrufe, 10 Antworten
Hi Members,
Any help appreciated in advance.
The wall I am trying to join misses the roof when I use automatic "attach top/base" tool. One side will reach the underside of the roof but the opposite side stays squared off. I have tried to move around the location of where the wall end is but this has no impact on the join of the roof.
Normally I end up just editing the profile manually, not a problem just a nuisance.
The wall in question is the front elevation with the circular window.
Kind Regards
Shiv
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: shivraj.panaich
Is it one roof or two joined roofs?
Nachricht 3 von 11
@shivraj.panaich: If I understand you correctly, I have had the same issue. Resolved by splitting the wall.
Nachricht 4 von 11
shivraj.panaich
als Antwort auf: ToanDN
One roof at the top with a single wall join just one half aligns itself and the other side remains squared off. Happens most of the time not sure if its something I am doing wrong or a glitch
Nachricht 5 von 11
shivraj.panaich
als Antwort auf: barthbradley
Splitting the wall works as a workaround but if a move the walls they revert back to the original problem.
I presume this is an error rather than something I am doing wrong on my end?
Nachricht 6 von 11
Its because of how you have drawn the top part of the wall.
If the base of the wall is higher than the eaves level, and the wall is wider or equal to the width of the roof then it causes the error you have to. Below are some screenshots that might explain it better.
1 - wall base lower than eaves. Everything works fine.1 - wall base lower than eaves. Everything works fine.2 - Wall base higher than eaves. Causes issue2 - Wall base higher than eaves. Causes issue3 - Pull in the sides of the wall (so there is at least 1 mm of vertical wall) to fix3 - Pull in the sides of the wall (so there is at least 1 mm of vertical wall) to fix
It might not be an ideal fix, but its how i have always got around it
Nachricht 7 von 11
als Antwort auf: Anonymous
@shivraj.panaich wrote:
"Splitting the wall works as a workaround but if a move the walls they revert back to the original problem.
Why do you need to move the wall after you split? Put it in the correct location first and then split it in two and try attaching to roof.
Nachricht 8 von 11
Sahay_R
Share the file.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 9 von 11
The two provided workarounds are the easiest ways to address your problem.  Other ways are edit the wall profile manually and lock the top profile lines to underside of the roof, or create a mass in place then Wall by face.
Nachricht 10 von 11
shivraj.panaich
als Antwort auf: Sahay_R
Hi Rina,
File attached
Thanks :leicht_lächelndes_Gesicht:
Nachricht 11 von 11
shivraj.panaich
Hi Alex,
Just had a look at the solution you mentioned. That is indeed the problem with the wall. I have aligned to inside of the roof and worked perfectly.
Thank you :leicht_lächelndes_Gesicht:
