I am a beginner. In Revit 2012 the roof view just showed up. How do I get it to view in 2018? I go to the Roof view after creating full height walls and they do not show under the roof view tab. My walls are full height from Level One to Top of Parapet with no interruption at the roof level. This is a flat roof with a 6ft parapet. 30 ft parapet at the entry. Thank you for your help. -Chuck Hoffmann
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Thank you much and for the quick response also. I will give it a shot again. I tried this before but was not completely confident I was on the right track.
Just re-read - saw that you are not able to see the roof. In the Roof plan view change the VR to see the top of the roof as well.
Create a Roof Level - you will need to be in an elevation view for this.
Architecture>>Level
Then
View>>Floor Plan.
A dialog box will show up with levels that do not have a floor plan associated. Select the Roof Plan level.
