I downloaded a tile family used for hips ridges and rakes from a tile MFG. Unfortunately, there is no way to properly rotate the family into the correct position.
I have been trying to recreate this using an adaptive family. Long story short, I simply don't understand how to use a combination of a point and adaptive point to get the rotation angle to control the tile family.
I've uploaded the original families to show the intent and I'm looking for some advice on how to properly create this in the adaptive component family.
Josh
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
This?
It's a Face-Based Family. Easiest way to do that, would be to create a 3D Beam (W Shape is good) along the hip and then place the Tile Family on the Beam's surface (Face). TIP: Make sure the Placement Plane for the Beam is set to Level when you place it.
Edit the Line Based family you have >> Edit the single tile and host the Swept Blend on a Ref. LINE hosted on the Front/Back Plane. Then give that an angle >> Load into the Line Based, overwrite and associate...Outcome is as below GIFs
Edited Family also attached - version R2022.
