Roof thickness not showing in section
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1058 Aufrufe, 4 Antworten
I made an octagon roof at the thickness of 125mm. In the elevation I can see the thickness of the roof. However, in the sections it shows that the bottom of the roof is flat. ( no thickness) I have tried messing around with the roof properties, but it it doesn't seem to work. Any suggestions would be appreciated.
Thank you
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
I'm not seeing a problem. Are you possibly mis-reading what you're seeing?
...if you reduce your Section Far Clip to 0'-1", does it look right?
Nachricht 3 von 5
I don't see any problems either. Do you mean the walls not reaching the underside of the roof? If so, select the walls and attach their top to the roof from the wall menu ribbon.
Nachricht 4 von 5
als Antwort auf: barthbradley
Yes, I misread the the section drawing. Thank you for pointing that out. I just realized that the thickness was showing properly in the top of the roof.
I appreciate your time.
Nachricht 5 von 5
I was reading the the section wrong. Thank you guys for point that out.
I appreciate your time!
