Is there anyway to do this in revit? I need to produce a shop drawing desassembling a roof in pieces.
please adivice
thanks
Wil
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hello
You can use two tools in Modify ribbon in Revit.
1. Parts - To create different parts of the roof.
2. Assembly - To create drawings and sheets.
Parts and Assembly
Thank you guys. This tool is fantastic and just what i need to produce shop drawings. However, I still have a question for you. When I placed the different views on a sheet I noticed that the plan view is not exactly the real dimension of the roof part but the plan projection of the roof piece. Is there anyway I can get the real dimension of the roof piece and not its plan projection of that piece?
Guys one more question regarding this issue.
Is there anyway to separate the roof in slabs when converting in parts? I converted a hip roof to parts but the whole roof remains on part. I would like to have each triangle to be its own part.
thanks
Will
I don't understand how to do this simple cutting.
Any body?
