Roof: Sloped layer
Roof: Sloped layer
XXalessio.amodioXX
Message 1 of 8
Roof: Sloped layer
XXalessio.amodioXX
Hi all,
I want to achieve smt like in pic. I have divided the roof in keys and applied variable layer. Unfortunatelly once changed roof subelements, roof is having several internal slopes (Tringolarization).
Any Idea?
Replies (7)
Message 2 of 8
bin
You can try this:
1. Create a roof type with 2 layers, once of which is variable.
2. Create a flat roof with an opening in the middle.
3. Add 4 split lines from corner to corner.
4. Modify the height of the edge in the middle (might need some math to get the 2degree)
5. Cut the part using a model in place void.
Message 3 of 8
bin
No split lines required.
Message 4 of 8
martijn_pater
Above works. You could also do it using modify subelements (like earlier topic if I recall), draw symmetrical at first match height (1) then edit boundary. Think that would do it also... (used add points only)
using modify subelementsusing modify subelements
edit: ow, and ofcourse set floor type assembly bottom layer to variable, top to fixed. But I think you had that already, anyway just to complete the answer... 🙂
Message 5 of 8
XXalessio.amodioXX
Instead of using void, it is possible to cut the roof using ref. plane?
Message 6 of 8
martijn_pater
No. But another option could also be to model it in place entirely (roof category), not so easy to change the assembly though (although you could add parameters).
Message 7 of 8
XXalessio.amodioXX
Message 8 of 8
martijn_pater
@XXalessio.amodioXXOw, but you can do the same thing with roofs. I thought you were talking about a floor. Modify subelements same as in post 4.
