Roof Slope
Roof Slope
Roof Slope
How can I add a degree sign to the roof slope? like the lower image. Also , how can I add teh text whch says 'pitch fall'?
RDAOU
Hey @Anonymous
  1. Select the slop annotation tag
  2. In the properties Palette click Edit Type
  3. Scroll down to Text Section
  4. Click Unit Format
  5. Change to Decimal Degrees (Make sure to set the unit symbol too to degree)
Alternatively; if your project's units is set to degrees...you can insted of step 5 above, just check "Use Project Units"
For the Text: select the tag; & fill the Suffix in the Properties Palette
awes
Please
a) select slope annotation, edit type, select unit formats, change unit format
b) select slope annotation, give pre- or suffix
