Hello everybody
First of all, apologises If this is a very easy question or it has been answered before, I have tried to fix it watching tutorials and previously asked questions but I am not succeeding.
I want to get these kind of roof:
which has a first slope to one direction, and then the slope of the other direction changes its steepness in the middle.
I tried to do it using three different roofs, but I can't seem to merge them quite right.
I tried slop arrows, but it doesn't allow me to even create the roof.
Any suggestions? Thank you
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Try roof by extrusion and then cut it to desired shape with a void or vertical opening tool.
@Anonymous
Massing works nicely ... mentioned above but here is a screencast
I'll add another method tho the list of suggestions here: Do this roof as a floor and then use Modify Sub Elements to "shape" it.
Carl, this roof is similar to what is referred to as a "Gambrel Roof". Google that term and you should find some helpful video tutorials.
Good luck.
