roof shed joint
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Mohamed_Arshad
395 Aufrufe, 3 Antworten
roof shed joint
hii Geniuses
i need to create a roof shed like shown image, kindly refer the image and give hands to solve this issuse
when i created the shed slice not cutting the shed fully, only partially cuts. i too shared the image below kindly find the attachment.
model file also attached
Thanks & Regards,
Mohamed Arshad K
3 ANTWORTEN 3
Nachricht 2 von 4
MostafaElashmawy
als Antwort auf: Mohamed_Arshad
You need to creat a model in place void to cut the roof as needed.
check attached file.
Mostafa Elashmawy
Nachricht 3 von 4
Mohamed_Arshad
als Antwort auf: MostafaElashmawy
Hii
thanks for your answer, if it possible to create a small video on that. i do that void but it showing some error.
it possible to create a small step by step video of that cut
Thanks & Regards,
Mohamed Arshad K
Nachricht 4 von 4
MostafaElashmawy
Please check below video.
https://knowledge.autodesk.com/community/screencast/d69d5e8d-b1c9-4a5d-920c-c400db1d6908
Mostafa Elashmawy
