Roof sheathing over fascia
5 ANTWORTEN 5
Nachricht 1 von 6
DeanMN777
541 Aufrufe, 5 Antworten
Roof sheathing goes over the top of the fascia. How do you do this when modeling in Revit?
The fascia tool in Revit locates the fascia proud of the roof edge instead of locating it correctly. Every video just seems to ignore this problem.
Tags (2)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: DeanMN777
Model the sheathing as a separate thin roof.
If you don't want two roofs, then create a void sweep picking the roof edges for path to cut the lower part of the roof, then place the fascia.
Nachricht 3 von 6
Problem?  What problem?
Nachricht 4 von 6
DeanMN777
als Antwort auf: barthbradley
I am pretty certain that is the standard answer from AutoDESK.
Nachricht 5 von 6
jdmwrxpower
Create a new profile family facia where you can adjust the angle. Once you do that you'll be able to duplicate an existing facia and change it to that and it will host like a normal fascia. Match the angle of your roof and join. It's completely obsurd in 2023 we don't have a simple extended offset we can add to roof edges part of the assembly. In the real world espeically with standing metal seam we bring the aluminum 2 inches off the face that discharges to the gutter. With revit I learned the model just needs to be good enough and the rest is annotation.
Nachricht 6 von 6
"Standard answer"? Mine was a question.  I don't understand what the problem is.  Are you wanting to offset/inset the Fascia?  There are Horizontal and Vertical Profile Offset Parameters under the Instance Properties of the Fascia. There's also a Parameter there to change its angle.  I don't know why you would have to settle for "good enough" as another commentator suggested.  You can model it in Revit exactly how it will be constructed in the field.
