Roof Seams Still Showing?
2 ANTWORTEN 2
Nachricht 1 von 3
morgan_hartt
203 Aufrufe, 2 Antworten
I have a fairly complex roof with a compound slope on one portion but 2 other faces of the roof section are perfectly aligned in position and slope but refuse to join with the abutting roof sections. I have tried using align tools, join geometry tool, and join roof tool but the seams still persist and you get no indication of if a tool has failed unless it causes an error so I am not sure if any of these tools are actually doing anything. I have only been using Revit for a couple of months and I am mostly self taught so it could be I am missing something obvious.
I highlighted the seams I am trying to remove.
https://imgur.com/a/EPEXh5L
2 ANTWORTEN 2
Nachricht 2 von 3
Mike.FORM
als Antwort auf: morgan_hartt
Is there a reason you cant make the roof from one piece? All the lines with the slope symbol are at 5/12 slope. The line circled in red is at 5000 * 5 / 12 elevation which is equal to 2083.3.
Sometimes roof joining can be a bit of a pain.
Nachricht 3 von 3
Source:
