Hi All,
I'm working about a building that has a particular type of roof (you can see it on the photo), I have managed to design almost all of parts, but I can't do the final section (the red solid that you can see on Autocad file).
I would like to design on Revit the same solid that I have designed on Autocad.
Can you help me, please?
Thank you so much.
Bye.
Antonio
P.s.
Please, to understand as I have worked, check the Revit file.
Thanks.
Solved by ToanDN. Go to Solution.
Seems like an odd piece. Two possible routes I would take.
-Create a (generic) family for this element.
-Adjust the floor slab, add your fascia and if needed use a void to cut the angle.
Louis
Please mention Revit version, especially when uploading Revit files.
Very difficult challenge. I spent way more time than I should have trying to figure it out. You have got a lot going on with this one little piece. Even modeling it has a separate is going to involve some gymnastics. I think it's going to need to be "sculpted" by subtracting geometry, but I can get close by using a Sweep-Blend.
BTW, don't you have problems working with your model in this orientation? I certainly did.
Good Luck. Post your finished product. I'd like to see what you come up with.
There is a proposal for solution for this, already, in "the other thread". That's why users should not post the same question twice.
I think his question is about a specific portion of the roof, not how to create the inverse sloped edges in general.
Nice tutorial on the slab edge approach you have shown in the other thread, by the way.
@ToanDN would you mind posting your rvt file for this. I'd like to see how you dealt with the interior condition (behind the fascia).
If I'm reading your image right, I'm betting that you used the same approach I did initially.
Modified flat roof to bring it forward a bit; squaring it off so I could wrap the corner with the existing fascia, and extend to end point abutment. Then I created a mass from the underside face of the fascia, and applied a Roof by Mass Face to it. Then I extended the angled wall (Attach Top/Base) to this Roof by Mass Face. The end result looked good from the outside, but not so good on the backside.
I just looked at his photo more closely and I realized I didn't even need to break the roof edge to two segments with two different profiles. I should have simply run the typical roof edge across and let it overlap the wall. The red mark-up area in the sketch is different than the photo and misleading.
Excellent Toan! I didn't catch that condition. Makes way more sense now. Good eye. Maybe I didn't catch it because I was slightly annoyed by awkward orientation of the building in Plan and 3-D views. Know what I mean? Maybe its me, but I prefer right angles in my views. Much less frustrating. HA!
Cheers!
Yes, sorry, there is the same question but the solution isn't appropriate.
Thank you.
Bye.
Antonio
Hi Toan,
You did an excellent work, well done.
You was very careful and meticulous.
Would you like to explain better as you did, please?
Thank you so much.
Best regards.
Antonio
Thanks for the kind words!
The steps below:
1. Edit footprint of the roof to get the correct location of the fascia.
2. Add fascia for the segment above the angled wall:
3. Create a copy of the fascia profile and edit it so that it will setback to stay behind the wall. Create a new fascia type using this profile. Add a fascia of the new type to the segment behind the wall. Join the adjacent fascias so they look clean.
4. Add a roof to cover the left over area and join it to the main roof. No fascia here.
5. Cut a section across the roof boundary line.
6. Go to the section and draw a Reference Plane by picking sloped bottom of the fascia. From the same view, select the angled wall and Attach its top to the Reference Plane.
ToanDN wrote: Go to the section and draw a Reference Plane by picking sloped bottom of the fascia. From the same view, select the angled wall and Attach its top to the Reference Plane.
BTW Toan: I must say, the use of a Ref. Plane to facilitate the wall attachment, was quite a nice touch. A much keener solution the one I came up with (e.g. creating a Roof by Mass Face from underside of fascia).
Take a bow, my man.
