Hi All,
I'm working about a building that has a particular type of roof (you can see it on the photo), I have managed to design almost all of parts, but I can't do the final section (the red solid that you can see on Autocad file).
I would like to design on Revit the same solid that I have designed on Autocad.
Can you help me, please?
Thank you so much.
Bye.
Antonio
P.s.
Please, to understand as I have worked, check the Revit file.
Thanks.
Solved by Alfredo_Medina. Go to Solution.
@Anonymous hello, is model in place > extrusion as a roof is acceptable to you? thanks
Try with a flat floor, with a slab edge family, as shown below.
This is "the other thread" about the same question.
Hi Alfredo,
Thank you so much for your help.
I have written the same question twice, sorry.
Your solution it isn't appropiate.
Look at the other post, please.
Thank you again.
Bye.
Antonio
