Hello all,
I'm relatively new to Revit but the learning curve has not been terribly steep. I'm wondering how I should go about deleting the underlap of the south roof in the attached images.
Jacob
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Are you using Full Revit Version? If so, you can use an In-Place Modeled Void to cut away those Roof elements. But there may be a better way. Can you post your file?
...actually, I think I'm misreading you. Can you redline the area of roof that you are talking about. Also, feel free to post the file.
You can use Modify > Join Roof tool to extend the Roof by Extrusion to the hip Roof. Then use Architecture > Dormer or Opening by face or Vertical Opening to trim the hip roof.
@Anonymous
Do you have these tools? use them or look for a good tutorial that shows you how to use them
@Anonymous
You need to find some good tutorials to follow roof aren't that hard to learn
Here is using Vertical opening to trim the roof as suggested earlier.
