Roof overhang
Roof overhang
Message 1 of 20
Roof overhang
Hi
I am having problems with roof overhead. One of the walls does not need to be overhanged and that’s where my roof falls off from one edge.
Parm
Replies (19)
Message 2 of 20
What do you mean? Do you have different plate heights?
Post a picture.
Message 3 of 20
Hi
Please see the attached link. File was too big to send.
Parm
https://drive.google.com/file/d/1l3XwPWaajJxyw3QwH1D0J_ucpIKli63w/view?usp=sharing
Message 4 of 20
Hi
please see the attached picture and ignore the porch roof joining comments. I have fixed It already
thanks
Parm
Message 5 of 20
Yeah: you have different plate heights. No wonder. If you want to do this as a monolithic roof, you will need to adjust the offset of the sketch lines to compensate for the difference in plate heights. Looks to be a negative offset of 150 at garage front and side walls.  This change will affect your gutter and soffit. You'll need to redo those elements as well.
FYI: the garage stem wall (that supports the garage walls) is typically flush with the  top of slab that supports the main house walls in SOG construction. In other words, your garage walls are the same height as your house walls. Do you get what I mean? There doesn't need to be a plate height difference.
Message 6 of 20
Hi
Thank you for your response. I didn't quite get what you mean by offsetting sketch lines. Is it possible for you to make the relevant changes in the revit file I sent above and send it to me. Your help is appreciated.
Regards
Parm
Message 7 of 20
chrisplyler
Edit the roof sketch. Select one of the sketch lines. Look at its properties.
Message 8 of 20
...or he could just raise his garage walls so that the plate heights are the same.  Smiley Wink
Message 9 of 20
georgehobel
barth.. FYI...you've got your grade outside the garage higher than the slab height.  That's going to pond water inside your garage.
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 10 of 20
@georgehobel.  You pulling my leg? Looks right to me.
...okay: the garage floor slab and stem wall are not monolithic; they're done in separate pours. So, yes, the pic is technically wrong.
...I hope you're not a plan checker in any jurisdiction I build in. You're tough! Ha!
...actually, even the rebar is wrong! ARRGH! Smiley Frustrated
Message 11 of 20
@Anonymous wrote:
Hi
Regards
Parm
Select the sketch line and change Offset from Roof Base value.  But IMHO what you have is geometrically correct.  You can fix it to bring the non-overhanging eave to the same height as the overhang eave but you will create the same problem on the other end.    I would leave it.
Message 12 of 20
georgehobel
I'm just taking notes...
Hope you're not one of those "I know how to do it, I saw it on TV" kinda guy....
George Hobel
Message 13 of 20
georgehobel
@ Pam... just out of curiosity... what's the reason for not having an overhang on that end?
George Hobel
Message 14 of 20
@georgehobel: What does that mean? I'm not following. FYI: 25 year of practical experience. You?
Message 15 of 20
Friendly neighbor not thrilled by an overhang lapping the fence, maybe?
Message 16 of 20
georgehobel
that's what I was thinking... either that or a real tough inspector, measuring the setback to the overhang...
@Anonymous...LOL.. "practical" is almost irrelevant these days.. The only thing that matters today is what they think you know.
George Hobel
Message 17 of 20
@georgehobel: I did find this on TV. Does it help?
https://www.youtube.com/watch?v=xzICeh1qAKc
Message 18 of 20
@Anonymous: Never mind all this bantering about overhangs. If that's you design intent, and it's allowed; then go for it. The issue is with your garage wall sill/mud plate being anchored to the garage floor (which is sloped for drainage!). That not going to work; plain and simple. And, that's the only reason I can see for the 150 mm offset difference between the top plate of the main house walls and the garage walls. Elevate your garage walls! Put a stem wall under them and call it a day. No issues with the roof now.
Message 19 of 20
Hi George
Thank you for your feedback. The garage wall needs to be built on the boundary for that side. That's why I can't have overhang on that side.
Cheers
Message 20 of 20
Hi Barth
Thank you for your suggestions. Yes I have two different height walls and that was causing the problem. I fixed them up and its all working fine.
Regards
