Roof opening
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
hliS658H
1049 Aufrufe, 2 Antworten
Roof opening
Is it because some setting in the model, the roof opening cut is not selectable for editing. Even after I delete the roof, the cut is still there invisible, once I make a new roof at the same spot, the opening shows automatically. When I export the roof to a new file, it is selectable and editable. What would be the setting? Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
Lachlan-JWP
als Antwort auf: hliS658H
There are manty reasons why an element may not be selectable / hiddin in a particular view.
Can you provide some more information please?
Is the issue that you cannot select the shaft at all or is it completely invisible in all views?
Is the shaft selectable in any other views? If you create a new 3D view, can you select the shaft?
How did you create the shaft? Using the opening tool, or is it an in place mass?
Is the shaft pinned?
Have you checked the view settings for Shaft Openings both By Element & By Category?
Nachricht 3 von 3
hliS658H
als Antwort auf: Lachlan-JWP
I finally figured out the reason that I can't pickup the roof opening cut is because I isolate the roof to work on it, once I reset the view, I am able to select the opening cut. No wonder I often have this issue because I normally isolate roof to work on it. Now, lesson learned.
