Roof line is below 2nd floor level
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
nancywelc.ms071.9.90
389 Aufrufe, 1 Antwort
My design has a roof line below the 2nd level I copied rac_basic_sample_project.rvt sample file and constrained Roof line to top of external wall causing Roof plan displays the 2nd Level and 2nd Level plan does not show the external walls I want roof plan with only roof and the 2nd Level with only level not with roof included
To correct it the roof level put the top level with roof slab negative base offset thats the only solution I can work out
 So question do people know a better way so I can place roof slab without negative offset and at roof base level?
What is your personal opinion?
Screenshot from 2022-03-20 07-32-25 sample project rac_basic_sample_project.rvt
Screenshot from 2022-03-20 07-33-11 my personal project
1 ANTWORT 1
Nachricht 2 von 2
Issue solved for anyone have this problem
create ceiling level
constrain level 1 wall to ceiling and view range bottom clip ceiling
