Roof joins of intersecting dormer
4 ANTWORTEN 4
Nachricht 1 von 5
466 Aufrufe, 4 Antworten
I am trying to do a roof join of 2 separate gable roofs
the bottoms of both gables are the same height
the roof which will be the dormer is entirely within the footprint of the main roof
therefore the roofs are intersecting in some areas
trying to do a roof join to extend the edge of secondary roof to face of primary roof
utterly ridiculous if revit cannot make a dormer that doesn't extend outside of the footprint of the roof or start at a higher height so as to not intersect it.
otherwise i will have to extend the roof overhang well past where it should be so i have roof to make a sliver of room outside of main roof footprint and extend it. This is not accurate to the design and unacceptable
otherwise i will have to extend second
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Join/Unjoin Roof tool usually does the trick. Post your file. Let's see what the problem is?
Nachricht 3 von 5
georgehobel
Theres always more than one way to do something...
George Hobel
Reflections of Charlotte
Residential Building and Design
Nachricht 4 von 5
als Antwort auf: georgehobel
...that's what she said.
he, he. That one never gets old.
Nachricht 5 von 5
als Antwort auf: barthbradley
