Roof Half-Round Intersection
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
BigPicture045
886 Aufrufe, 8 Antworten
Trying to model these half-round roof interesections:
I have tried Model-In Place. The problem is that I cannot align it to the roof slope. The model in place will not rotate:
Any suggestions?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: BigPicture045
Why don't you model the roof as a Roof by Footprint using a Polygon shaped sketch?
Nachricht 3 von 9
BigPicture045
als Antwort auf: barthbradley
@barthbradley
The roof is modeled by footprint. You can see that from the second image, right? I am talking about the middle part where the roof planes come together. See where it is raised up?
Nachricht 4 von 9
Model in place Sweep using Pick 3d Edge to create path.
Nachricht 5 von 9
BigPicture045
als Antwort auf: ToanDN
@ToanDN
That worked. Thanks.
Nachricht 6 von 9
Ah! I see now. Ridge cap.  Why not model it using Roof Fascia?
https://www.youtube.com/watch?v=sHwmn6Rfecg
Nachricht 7 von 9
BigPicture045
Thanks for sharing that, adding that to my arsenal.
Nachricht 8 von 9
Hey @BigPicture045: thought you might be interested in the Ridge Tile Line-Based Family that is in the attached Project.
Nachricht 9 von 9
syman2000
Here is my other solution you can use for next project. It is using railing. All you have to do is pick the ridge and then pick the roof and it will host to the roof.
