Roof/floor, with different thickness
giovanni.bonavia.pela
Message 1 of 9
Hi All.
Is there a way to produce a floor/roof that has a sloped lower layer and a flat finish layer?
I have the structural slab that is sloped but the finish floor on top must be flat.
See attached sketch.
Replies (8)
Message 2 of 9
rxi.gg
Check this
https://yolandamuriel.com/2019/03/27/revit-architecture-422-modificar-el-grosor-de-la-capa-de-una-cu...
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 3 of 9
Hi if i use that option the thickness variation is on the upper side and not the lower side
Message 4 of 9
rxi.gg
You can do it in the layer you want
Message 5 of 9
rxi.gg
I understand you now, sorry. You can't keep your upper face flat 😕
Message 6 of 9
No. Model two floors and join them.
Message 7 of 9
I was scared that was the option. Unfortunately the floor difference is too much to have them to fill the void.
Another limit. Hopefully it will be fixed 🙂
Message 8 of 9
Can you share a section where it is "too much"?
Message 9 of 9
Something like this?
If I make the second roof on top and then join, this is what I get.
And this is wrong again, because the insulation is shown as getting thinner rather than the gravel getting thinner. Is it maybe a matter of layer Function? not sure....I just thing that this is another work around.
