Roof edge problem
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
672 Aufrufe, 6 Antworten
Roof edge problem
Hi all, is it possible for roof not following the footprint but forming a rectangular roof edge? Thanks all.74862E57-B205-4FAC-A1F6-D40E98B67802.jpeg
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: Anonymous
you can try model in-place extrusion for this roof? thanks
Nachricht 3 von 7
RDAOU
@Anonymous
Do the following (See GIFF Below - applies to all types of roofs :enttäuschtes_Gesicht:
  1. Select the Roof
  2. On the Properties Palette >>> Set the roof Rafter Cut to: Two Cut Square
  3. Set the Fascia Depth = Roof overall thickness
Nachricht 4 von 7
als Antwort auf: RDAOU
Hi RDAOU, Thanks for your reply.
I tried it on my case (a single side pitch roof), it can only solve the lower level (in green) but not happening on the upper level( in red) as attached, any clue?
Thanks again.
Leonard
Nachricht 5 von 7
als Antwort auf: ennujozlagam
Hi Ennujozlagam, Thanks for your idea. It seems working with a mass extrusion. Just that I am new to revit and it take me sometime to create a reference plane with my 2 way pitch roof. I am also checking if the massing can have the same roof feature ( like creating gutter and fascia) Thanks a lot. Leonard
Nachricht 6 von 7
You don't need to create a mass. Use Opening by face tool cut the top edge of the roof squarely.  See screencast.
https://knowledge.autodesk.com/community/screencast/42b5ac5a-0325-4b02-88c1-99591e834387
Nachricht 7 von 7
als Antwort auf: ToanDN
hi Ennujozlagam, Thanks a lot for your reply again.  It is a very smart solution.  Thanks. L
