Hello all,
My apologies if this has been discussed, also newer to Revit off and on. I'm trying to draw a couple of roofs (please see attached) but keep getting " roof cannot be drawn" ? any ideas are greatly appreciated, thanks.
Dallas
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Hard to advise you without knowing what you did to throw the error. Easiest way to do those, would be creating 2 roof-by-footprints and joining them -- or 2 roof-by-extrusions.
you can do it using two Roofs.
If Join Roofs command doesn't work, then, use a Void to cut the not needed part..
Constantin Stroescu
...and then use the Dormer tool to cut an opening through the target roof underneath.
Or not.
Thanks Barth, sorry, yes I was in roof footprints, haven't tried Extrusion but will certainly give it a shot, thanks.
Dallas
