Roof adding to variable depth for no reason
8 ANTWORTEN 8
Nachricht 1 von 9
gnarkill283
345 Aufrufe, 8 Antworten
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: gnarkill283
Looks like a cross-section of a sloping roof.  Looks normal to me.
Place a Longitudinal Section through the Roof, and it will look the way you are expecting.
Nachricht 3 von 9
gnarkill283
als Antwort auf: barthbradley
sorry forgot I was in the wrong section - it adds 5" extra depth for some reasonimage.png
Nachricht 4 von 9
Did you shape edit the roof through Modify Sub-Elements?
...if you did, and you don't want the Variable layer, just uncheck Variable.
Nachricht 5 von 9
gnarkill283
I think i figured it out - it has to do with having to subtract the thickness of the default slab with the sub element point desired height. So say I want the high point of a flat roof to be 11", I don't just put 11" for that points elevation but instead have to subtract 5" if the roof's materials are set to 5". This means I'll have to change all my points elevations
Nachricht 6 von 9
Why don't you just offset the Base from Level?
Nachricht 7 von 9
gnarkill283
what do you mean - that last image has the base offset but then slabs overlap
Nachricht 8 von 9
The value you enter to the point is the delta between the new elevation and the original-unmodified elevation of that very point.
Nachricht 9 von 9
@gnarkill283 wrote:
what do you mean -
I don't know what I mean anymore.  I have no idea what you are trying to do.  It just sounds unnecessarily convoluted.
...anyways, I got a team of NASA Rocket Scientists working on it right now. I'll get back to you. Smiley (zwinkernd)
